6th Gen ('00-'05): fuel injector harness and map sensor questions....
Old Jan 27, 2014 | 11:55 PM
vikesfan's Avatar
Default fuel injector harness and map sensor questions....
pinkish wire is always +
and then the "off" color is the ground
right?
can the n/a pcm "read" the 2 bar map sensor from the l67?
finishing things for my top swap, and this is one of the last things i have to do.
only things left are....
solder in new injector harness connectors
figure out map sensor and solder in connector
run new vacuum lines
flash new bin file to pcm
and then i can start it up.
Old Jan 28, 2014 | 02:42 AM
l67ss's Avatar
Killer man . But yeah, the pcm can read the new map
Old Jan 28, 2014 | 09:32 AM
vikesfan's Avatar
i guess i should be more specific by what i mean by "reading" the map, is that i know the pcm will "register" the signal and will see it go from vacuum to atmospheric pressure, and it will "read" the boost, however, will the N/A 3800 PCM tables be able to reference that boost in order to accommodate more fuel and adjust timing like in the L67 bin files???
peteygnyc
Aug 28, 2013 12:23 AM
MJClemm
May 19, 2013 12:01 PM
Dam20735
Sep 7, 2012 01:30 PM
Nova1585
15
Oct 11, 2009 04:44 AM
Vladimir
Jun 10, 2009 05:12 PM
