fuel gauge problem
Old Mar 26, 2011 | 11:52 PM
ndgrown's Avatar
Default fuel gauge problem
on my 2001 monte carlo the fuel gauge shows the correct level until the car starts moving and then it goes to full. also having problem with temp gauge occationally inoperative. both gauges are in the same cluster. any ideas what is going on?
Old Mar 27, 2011 | 02:23 PM
Jon's Avatar
Jon
i have the same problem in my 2000 monte(Gas), think it could be just a bad sensor
Old Mar 27, 2011 | 04:28 PM
Mike 00LS's Avatar
The gas gauge issue is probably being caused by a bad sensor. However, the temp gauge becoming inoperable, could be caused by a bad motor.
Old Mar 28, 2011 | 05:24 PM
ndgrown's Avatar
does the fuel gauge and temp gauge have different motors , because both gauges are in the same circle cluster
Old Apr 2, 2011 | 07:50 AM
Mike 00LS's Avatar
Yes they do. Each needle has it's own motor.
Bobbydd21
Jul 23, 2014 10:29 PM
01MonteRookie
Feb 25, 2014 04:09 AM
UWAdventurer
Feb 14, 2014 09:23 PM
robknight13607
Mar 20, 2013 09:14 AM
04chevyboy
Jan 29, 2012 09:50 PM
