Fuel gauge not working
Old Mar 23, 2008 | 01:11 PM
punkmasterflex9's Avatar
Default Fuel gauge not working
Hi everyone, my fuel gauge is pretty much always at either half full or slightly above despite how much gas I have in my tank. I pretty much go by my mileage and the trip computer to see when I should fill up next, nota huge deal but it gets annoying. Does anyone have some suggestions onhow to fix this? Thanks!
Old Mar 23, 2008 | 05:32 PM
Cloud_Master's Avatar
Default RE: Fuel gauge not working
I just acquired my grandpas 01 LS MC, and i was going through his receipts for the car. He at one point also had the fuel guage not work, the shop changed out the fuel level sensor, which is in the tank. That fixed the problem. If it's anything like my escalade, the sensor and fuel pump are all one unit..........
Old Mar 23, 2008 | 08:15 PM
mickey's Avatar
also make sure to check the ground for the guage at the tank.
if you get any corrosion in there it will break connection.
but honeslty the bad news is i think it might be the sender mos tof the time if you somthing liek this at half tank readdings it is the sender or the tank level sensor.
Old Mar 23, 2008 | 09:21 PM
2000+ Monte's also seem to have an issue with the guages going bad.
I had to have my guage cluster replaced when the temp guage suddenly shot up WAY past maximum read out.
If it's not the problem the others mentioned with the sending unit,this may be your problem.
Old Mar 23, 2008 | 09:34 PM
2000LS's Avatar
i'd put a fuel level sensor in it, the lil fingers on the sensor wear out. if you feel youre competent enough, theyre pretty easy to change on our cars thanks to the access panel in the trunk, or if you have it done the labor isnt a big killer because of the access panel.
Old Mar 25, 2008 | 04:29 PM
bowtietech's Avatar
Most likely a fuel level sensor.If possible have your Monte Carlo's PCM scanned for diagnostic trouble codes. Diagnostic trouble code P0463 would be the fuel level sensor.
DAVESS2002
Apr 26, 2016 11:52 AM
mercury2
Mar 14, 2015 02:03 PM
SUPER SPORT MC
Jan 3, 2010 10:36 AM
neel2008
Jan 8, 2007 12:23 AM
01whitess
Dec 20, 2005 03:29 PM
