front end
Old Oct 6, 2012 | 07:42 PM
boggie's Avatar
Question front end
Does anybody have the problem with there front end of it making snapping or a poping or a creaking noise and if so how did you correct it . It sound like the left side of the car but at no specific time sometimes when it turns or going slowover a bump and some when I accelerate.
Thanks
2001 SS
Old Oct 6, 2012 | 08:13 PM
Mr Grizzly Mint's Avatar
mine just started doing this on front left.
Old Oct 6, 2012 | 08:28 PM
Manning95444's Avatar
Is this while you turn, Break, accelerate, ect. need a little more detail.
Could be body to chasis mounts or steering issues also CV joints, Most likely is tie rod ends or ball joints wheel bearings there is alot to go with so as much detail as possible would be great.
Old Oct 6, 2012 | 08:38 PM
Does it happen when you turn the wheel - it could be the Intermediate Steering Shaft - it needs to be greased - very common on these cars.
Old Oct 6, 2012 | 08:43 PM
The Strut bars on mine pop alittle .. the bolts where loose..LOL
Old Oct 6, 2012 | 09:08 PM
Like the afore mentioned...maybe a little more detailed info would help....
Im leaning toward a axle issue...broken...or even bad CV joints, (dry) no grease...
Old Oct 6, 2012 | 09:47 PM
mine does it when I hit a bump. Its like when I broke a strut mount havent checked tho.
Kelt
May 4, 2007 01:11 AM
BeachBumMike
Mar 14, 2007 11:22 PM
neel2008
Jan 17, 2007 12:57 AM
yzf125
Apr 30, 2006 11:21 AM
warpath
Apr 6, 2005 09:20 PM
