two cigarette lighters in monte ss 2003....problem
Old Oct 7, 2015 | 06:14 AM
Kenny Guido Temprano's Avatar
Default two cigarette lighters in monte ss 2003....problem
my phone charger broke apart while nestled in the front cigarette lighter holder. i carefully pulled it out making sure i dont touch the light as to not short it out. well i plugged in the charger afterwards and it wasnt working. i tested it with my tester and still nothing. i used other chargers and again, nothing. i then went to the one in the back center console and it was working. i checked the fuse on the side of the dash board and it was working. are there 2 seperate fuses for the cigarette lighters?
Old Oct 7, 2015 | 09:07 AM
According to my 2002 manual it shows two. If you email me at modp343 at gmail dot com I will email you the manual. The 2003 and 2002 should be very similar if not the same as far as fuseboxes.
Old Oct 7, 2015 | 11:20 AM
ohara's Avatar
If I remember correctly I believe the fuse for the front cigarette lighter is located on the fuse box on the passenger side of the dash
Old Oct 7, 2015 | 12:04 PM
I believe you are correct Ken. That is what it says on the diagram I have in the manual.
