fog lights 97 Z34
Old May 22, 2008 | 02:01 PM
1WX27's Avatar
Default fog lights 97 Z34
I have a wierd situation. My 97 has factory fog lights- they are on all the time with the DRL and at night with the headlights. I don't have a switch that operates them. What was GM thinking aside from providing Sylvania with a continual income stream. On the other hand, i haven't seen any other MC's with the same setup. Any ideas?? BTW, sorry for the pic and the passenger side fog has been replaced and is fully functional.
[IMG]local://upfiles/3919/250B38968C924F3E9B5CA2236634DCD7.jpg[/IMG]
Old May 22, 2008 | 04:46 PM
mrl390's Avatar
Default RE: fog lights 97 Z34
Im not sure what you are asking? Are you asking how to put a switch in to turn them off? I put fogs on my 97 z34. The switch has 1 ground wire running to it, one wire running to it from the headlights and one wire running to the relay. In your case,you may be able to put a single stage switch in the power supply wire that runs to therelay or do the same in the ground wire to the relay. Im pretty sure that would work.
Old May 22, 2008 | 06:30 PM
mickey's Avatar
for the most part you cn use a switch in either the power or the ground it is a matter of making a complete connection threw the whole thing. I.E. make a complete circut.
so the way he says will work OR you can take the power wire and cut it put a switch in it and mount it where you can get to it easily.
This will allow you to turn them on or off.
If you have a place for it and feel like gettign creative you can get a switch out of a 6th Gen monte and they are desinged to work when you push them on but then when power is cut they break circut and wont come back on till ya hit the button on them to do so.
Old May 22, 2008 | 07:46 PM
mrl390's Avatar
Well obviously you will have to lengthen the wire you put the switch in. Didnt think that needed to be addressed because what useis a switch if you cant reach it to use it, lol.
Old May 23, 2008 | 10:16 AM
1WX27's Avatar
Thanks for the replies and sorry for posting more of a statement rather than a question. I was looking to see if there was anything from the factory that you are aware of that would stop them from being on all the time- I thought since some vehicles are able to deactivate DRL, maybe there was a way to only have the fogs come on if I turned the lights on- they are on the dash sensor so they switch from DRL to headlights on their own. I will likely change out the lights since the lenses are a bit cloudy and the bulbs are I think only a 27 Watt, I don't want to continually have the fogs on at that point.
rg9johns
Jan 2, 2022 05:51 PM
rg9johns
Aug 22, 2014 10:46 PM
guzzimane
Apr 27, 2014 10:02 AM
dc1
Nov 9, 2013 01:48 AM
mickey
Jun 29, 2005 11:40 AM
