Fog lights
Old Mar 1, 2008 | 11:22 AM
mlp313's Avatar
Default Fog lights
I Have a 06 mc Lt and its bone stock all I have is 20% tint and a rear view cam. i have some 6x9 and componets (infinty) havent hooked up yet. The question I wanted to ask is were can i get some factory fogs, or maybe even some good looking after markets?
Old Mar 1, 2008 | 01:39 PM
RickCoMatic's Avatar
Default RE: Fog lights
It took me awhile to score some Factory Fog Lights from a Salvage Yard, but eventually they came through.
Factory is what you want. The ease of installing a Factory Pair is worth searching for them.
Wiring is another issue.
I thought my Monte was wired for the Factory Fogs. It wasn't! I had to run all my own wire and relays to keep the Fog Lights off the Body Control Module.
Wasn't too hard to do. Adding a Double Switch and a Double set of Relays with taps off my High and Lo Beams for triggering the Relays make it easy to have the lights come-on with Hi or Lo Beams.
Sylvania makes a Bulb that will allow you to use the Fog Lights as Road Lamps. 880 ST Silverstar Bulb for Factory Foglight
Old Mar 1, 2008 | 01:44 PM
Sir Monte's Avatar
Hey Rick what did your factory fogs cost?
rg9johns
Jan 2, 2022 05:51 PM
rg9johns
Aug 22, 2014 10:46 PM
guzzimane
Apr 27, 2014 10:02 AM
dc1
Nov 9, 2013 01:48 AM
mickey
Jun 29, 2005 11:40 AM
