6th Gen ('00-'05): FM not working on radio
Old Aug 22, 2025 | 01:23 PM
spamdaddy's Avatar
Default FM not working on radio
All of a sudden, the FM on my radio stopped working. The AM and SXM work fine. Anyone had this happen? How was it fixed?
Thanks
Old Aug 29, 2025 | 11:24 AM
So SXM uses it's own antenna. The FM/AM radio uses antenna lines that are also part of the rear defroster. There is a module hidden behind one of the rear interior panels that is connected to the process. I wonder if there is a problem with the connection to the rear glass or that module.
Old Sep 2, 2025 | 10:38 AM
spamdaddy's Avatar
Thanks for info. Any idea which panel?
Old Sep 4, 2025 | 08:13 PM
If my memory serves, it is on the passenger side, rear upper panel. I think you need to remove the clothing hook and it gently pops out.
Old Sep 5, 2025 | 12:41 PM
spamdaddy's Avatar
Thanks. I’ll check it out. Can’t be without my tunes.
griffseefeld
Jun 16, 2022 12:42 PM
96z34man
Oct 15, 2016 07:15 AM
lil bz
Nov 9, 2015 08:15 PM
avendo
May 18, 2015 06:52 AM
qbenjamin
Jul 31, 2009 01:46 AM
