6th Gen ('00-'05): FM not working on radio
So SXM uses it's own antenna. The FM/AM radio uses antenna lines that are also part of the rear defroster. There is a module hidden behind one of the rear interior panels that is connected to the process. I wonder if there is a problem with the connection to the rear glass or that module.
If my memory serves, it is on the passenger side, rear upper panel. I think you need to remove the clothing hook and it gently pops out.
Opinion Needed: FM radio not working on 2004 Monte Carlo
griffseefeld
Jun 16, 2022 12:42 PM
7th Gen ('06-'07): Radio Question
96z34man
Oct 15, 2016 07:15 AM
