Fluctuating Oil Gauge '04 SS
Hi
I just changed my air filter to a K&N Air Filter. Now either I never noticed before or this is because of the new filter, but when I accelorate the oil temp gauge rises and then when I lay off the gas it goes back down? Is that normal?
Thanks
Thanks
RE: Fluctuating Oil Gauge '04 SS
if nothing else put the old filter back in and run it around the block and see what happens but i wouldnt worry about it. as far as performance with the filter im not sure what you are suposed to get hp wise but i seen the hptv two weekend ago they were doing a new rustang and the cold kit added like 10 horse, i drop in filter probubly not as much. like tvw said, you could put it on the rollers but your lookin at a low hp gain.
ORIGINAL: chevy_jj
ORIGINAL: montejass
I would think the changes would be pretty much instant I would think. The PCM should make instant adjustments.
If you woke up in the morning and somebody had taken out your 3800 and put in a d15y2 from a 88-91 Honda Civic in your Monte, it'd take a while for you to get used to it, learn how long it'd take to pass, climb a hill, how much gas you need to give it when doing such. Same goes for the ECU when you do a mod that effects the airflow as much as a K and N does, cause you'd need to take it through the motions so it can see how much air it sucks in at WOT, at idle, at cruising speed, etc.
ORIGINAL: montejass
That is interesting. I wonder what that cycle time is? Maybe Chevy_jj knows and could offer some insight...
01 Monte SS
14
01-21-2013 12:57 PM
04chevyboy
01-29-2012 10:50 PM
