Flashing Check Engine Light
Old Sep 18, 2009 | 04:53 PM
bkb1255's Avatar
Default Flashing Check Engine Light
While driving home today the check engine light started flashing and then the car started skipping. Any idea what's going on? Got the codes and it said that #3 cylinder was miss firing. Needed a tuneup. Got that done and the check engine light is still on. How to reset it?
Old Sep 18, 2009 | 05:37 PM
Budsjlm's Avatar
if you can try to get the codes... that would help alot...
Old Sep 18, 2009 | 09:04 PM
MonteDriver's Avatar
define skipping, is it like the car has hit the rev limiter?
Old Sep 18, 2009 | 10:39 PM
vincenti's Avatar
places like Autozone will read those codes for free. see what the code says.
Old Sep 20, 2009 | 01:52 PM
TPI Monte SS's Avatar
If the motor is running fine now, you can disconnect the - terminal on the battery for a few minutes to clear the check engine light, or you can just drive it normally. The light will reset after 50 starts (IIRC) as long as the code doesn't come back.
Old Sep 21, 2009 | 08:36 AM
A flashing check engine light ALWAYS means there is a mis-fire.
If you wanna reset, do the battery disconnect or take it to a code-reader and have them delete the code.
But if the light comes back / still flashes you could still be misfiring and the tune-up didn't fix it.
Old Sep 21, 2009 | 09:47 AM
MAMONTE's Avatar
Took the words right out of my mouth...flashing is ALWAYS a misfire...I just experienced this in my 06...My code was I think P0300 if I remember...I know it was "random misfire"
Old Apr 9, 2017 | 02:32 PM
Steven Mccraney's Avatar
what caused the p0300 code? Thats what is currently showing on mine and ive recently done a tune up.
Old Apr 10, 2017 | 09:01 AM
Very very old thread. But P0300 is a random misfire, which usually is indicative of a fueling issue
RonKennesaw
Jan 5, 2015 04:49 PM
rjo98
Mar 3, 2013 06:47 PM
limited edition ss boy
Feb 23, 2012 08:13 AM
StanzManianDevil
Apr 8, 2009 01:25 PM
warpath
May 23, 2006 10:54 AM
