Fixed motor in gauge cluster, where do the needles go?
Old May 19, 2012 | 09:08 PM
jimbo7's Avatar
Default Fixed motor in gauge cluster, where do the needles go?
I just replaced the bad stepper motors in my 04 supercharged. It's been over a year in the making. Also fixed a burnt out bulb for the passenger thermostat. Wasn't too bad a job. Have to be very careful with the thin leads on the motors. Also, don't forget to plug you driver info screen thingy connector .
I can't get my boost and my temp gauge in the right spot. I also think my rpm is reading a little high.
What position should the boost needle be at ignition off, ignition on, idle, and crusing then letting off throttle? I remember it reading about 6psi at full boost. But I can't remember if it went to -10psi when letting off throttle on lets say normal highway driving.
The temp gauge I believe should read about 2 ticks left of high noon on the gauge when at normal driving temp.
The rpm's I believe should be at about 600rpm at idle when at operating temp and around 1750rpm when doing 65mph.
Old May 19, 2012 | 09:25 PM
look here, another member posted it.......
Originally Posted by 03SSLE
04 Intimidator
FWD Tech Guides '95-'07
103
Oct 12, 2020 08:32 AM
shotime105
Dec 7, 2012 10:27 AM
nighthawk626
Jan 28, 2011 10:04 AM
TETCarlo
Oct 11, 2010 12:25 PM
RussellUCF
May 28, 2008 09:43 AM
