Faulty Cabin Air Filter
Old Dec 3, 2009 | 08:38 PM
archebald23's Avatar
Default Faulty Cabin Air Filter
Had my oil changed a couple of days ago, when the car was returned, i noticed water seeping on the passenger floor, its apparently coming from the ac filter. I need to replace it. Found this vid on the net on how to replace cabin air filter, can you guys recommend this?
Old Dec 3, 2009 | 08:42 PM
mrl390's Avatar
Most likely its not the filter itself but the seal around the filter. If you do change it, even if the new filter comes with a seal, I would run a good bead of silicone around it so you dont have to worry about it leaking again.
Old Dec 3, 2009 | 09:23 PM
Wilco's Avatar
Make sure the seal is in good shape and clean the are as good as you possibly can. I did mine not long ago, it probably was never change since the car was made, and once I cleaned the seal and it's matting surface it worked like a charm and no leaks.
Old Dec 5, 2009 | 02:27 PM
skylark65's Avatar
make sure there is no buildup of leaves/ other crap around the cowl weatherstripping, and while your at it clean the water channel around the trunk, and around the doors. sometimes something as silly as a buildup of leaves & dirt in these aereas can allow water to seep, or sometimes pour into the vehicle. i've seen this happen quite a few times.
Laserblue06ss
Oct 25, 2023 08:51 AM
fastback4
Jun 14, 2008 06:03 PM
God_Bot
Mar 14, 2008 07:24 PM
RickCoMatic
Dec 16, 2007 07:15 PM
03SSdriver
Oct 5, 2005 08:13 PM
