Fans on Radiator
Old May 4, 2007 | 06:06 PM
04 Intimidator's Avatar
Default Fans on Radiator
I can't beleive I'm stuck on this. I can't get the fan shroud out from the front of the car on the radiator. It is loose and all wires are disconnected, but it is stuck.
Does anyone know an easy way to remove this without removing the radiator hoses and half the airconditioning?
I can't beleive I'm this far through my header install with fabricating new pipes, etc, only to be stuck by1 inch of fan clearance. =<
Old May 5, 2007 | 02:07 AM
Default RE: Fans on Radiator
Disregard. After reefing on it for a little while, it popped and I was able to get it 2 inches up. Just enough clearance and the headers are installed.
Just need to route the assessory belt, put a brace back in, tighten a clamp and hook up the oxygen sensors.
Old May 5, 2007 | 05:09 PM
mickey's Avatar
I hear they have issued a new wrench out for the Military it is call teh C-4 .
Works wonders on all sorts of things to include stuck car parts. and even when you have a dead ford in the way if you use enough it will move them off the road for ya to
slowtalker
23
Sep 11, 2023 10:46 AM
daves92camaro
Jul 15, 2011 10:10 PM
PUNK LIFE
Jul 30, 2010 02:27 PM
berettajeep
May 24, 2010 04:35 PM
monteriderLS
Jun 13, 2007 11:49 AM
