1997 monte engine cooling fans
Old May 5, 2007 | 09:04 PM
fastback4's Avatar
Default 1997 monte engine cooling fans
I don't believe they work. Where is the sending unit at on the engine..Can i make them turn on manualy? Regards....Tom
Old May 5, 2007 | 09:59 PM
scc24540's Avatar
Default RE: 1997 monte engine cooling fans
they are wired to the coolant temp sensor. you can unhook the sensor and they will run all the time the car is on. or you can just splice into it and run a switch to turn em on but its best to leave it alone
terrys03monte
Aug 9, 2010 09:43 AM
AlGeeEater
Sep 25, 2009 08:10 AM
chevygirl
Jan 12, 2009 10:12 PM
smolek37k
Nov 5, 2008 02:13 PM
starshinep
Jul 9, 2008 08:04 PM
