Fan fuse,relay or new fan?
Old 07-17-2013 | 12:22 PM
NYGiantsfan's Avatar
Default Fan fuse,relay or new fan?
Hey so I'm having trouble with my fans one works however the other one does not. I checked all fuses and found one of the mini 25 amp fuses (fan control 2) was blown. The thing is every time I replace it it blows almost instantly I took out the three relays in the first row in the fuse box under the hood labeled fan 1, 2, and 3 and accidentally mixed them with other relays, and noticed they have a 3 or 4 digit number on them I was wondering if someone can help me with which one goes into which port as well.
Looked up me prices for the fans just in case d they ranged from 90-140 and I would love to avoid paying that lol
Thanks guys.
Old 07-20-2013 | 01:14 AM
A05C's Avatar
If its blowing the fuse immediately then there's a short to ground somewhere in that circuit. Its extremely hard to diagnose wiring.
Check for damaged wires or cut wires
Old 07-22-2013 | 09:00 PM
Ok sounds like fun haha ill check for some wires i removed when i did some work, you think this is could be the issue even tho one of the fans works fine?
Old 08-15-2013 | 08:43 PM
can2tx's Avatar
Just replaced my fans because mine was having same issue. It fixed the problem. Initially I thought my water pump was going out, so I replaced it and the thermostat. Neither fixed the problem. Finally the CEL came on and it read a P0481. Checked the fuses and found the 25 amp fuse blown replaced it and then the car would operate a normal temp while idling, but afte driving a few miles the temp would climb to about 210-220, but no higher. Finally found one fan was out, replaced them and the problem is now fixed.
Ambera248
08-17-2015 07:25 PM
MJClemm
12-12-2012 03:21 AM
ohiobronco
08-28-2012 01:35 AM
spencerdad2010
08-08-2012 08:29 PM
JoeAsheville
02-16-2009 02:05 PM
