Factory Lock & Horn Honk
Old Feb 4, 2009 | 11:54 AM
Payneful13's Avatar
Default Factory Lock & Horn Honk
I've had my monte for a little over a year, when I press my lock button on my FoB, it locks, when I press my unlock button, it unlocks. I'm happy.
About a month ago, I added a new battery terminal that was large enough to add my amplifiers power wire to the terminal. Somehow in the barrage of horrible weather and disgusting road conditions...and my lack of a lock washer, my battery terminal came loose. It took me about 3 days to finally figure out that my + terminal was the root of my problems and I corrected it.
The day before I tightened up my terminal and added a lock washer, my horn started honking when I press my lock button. Every time I use my FoB to lock my doors, my horn honks once....
How do I turn off the factory lock horn honk? It's annoying. lol
Old Feb 4, 2009 | 01:10 PM
Default RE: Factory Lock & Horn Honk
start your car, turn the radio off
hold the tune button in for 10 seconds (I can't think of the ***** name!!!) and then your settings will pop up, like when you have to reset your oil life/tire pressure sensor.
scroll through the options and you will find the settings for the FOB and you can turn off the honk.
Old Feb 4, 2009 | 01:48 PM
Payneful13's Avatar
My factory radio hasen't been installed for about 8 months.
Old Feb 4, 2009 | 02:30 PM
kweef's Avatar
well that will make things alot harder...off the top of my head im not sure but read ur owners manual. it will tell u if there is another way to change the setting
Old Feb 4, 2009 | 03:15 PM
I think unless you have the radio installed, just for these situations (like in a trunk or something) you are out of luck.
I believe the only things you can reset without the factory radio are the Oil and TPMS.
Chevy Kid
Mar 14, 2014 06:59 AM
DerrtyD
Apr 26, 2013 11:49 AM
1SLOWSS
Nov 27, 2012 07:00 PM
xotmonte
Dec 27, 2010 11:21 AM
Spook
May 5, 2010 02:38 AM
