evap can
Engine Wiring Harness Connector Emis Canstr Vent VLV Sol JMPR WRNG Harn | eBay
it says I need this also,harness...do I really need it?
The EVAP Canister purge valve is located to the right of the coil packs, above the valve cover. A new harness should not be necessary unless it's an aftermarket valve with a different type of connector. Should be "Plug and play"
This what you need:http://www.ebay.com/itm/One-Evap-Eva...11dd19&vxp=mtr
or (same part confirmed with a dealer site because eBay incorrectly says It's not compatible with your Intimidator).http://gmpartsdirect.com/catalog/frameset.cfm
