evap can
Old Jun 26, 2015 | 04:28 PM
avendo's Avatar
Default evap can
On my car is it under my left rear quarter? 04 monte
Old Jun 26, 2015 | 04:57 PM
avendo's Avatar
ACDelco 214-2324 I bought this
Vapor Canister Vent Solenoid ACDelco GM Original Equipment 214-2324
Old Jun 26, 2015 | 05:02 PM
avendo's Avatar
Engine Wiring Harness Connector Emis Canstr Vent VLV Sol JMPR WRNG Harn | eBay
it says I need this also,harness...do I really need it?
Old Jun 27, 2015 | 02:33 PM
plumbob's Avatar
The EVAP Canister purge valve is located to the right of the coil packs, above the valve cover. A new harness should not be necessary unless it's an aftermarket valve with a different type of connector. Should be "Plug and play"
Old Jun 28, 2015 | 09:51 AM
avendo's Avatar
Guess i will cancel that part
Old Jun 28, 2015 | 09:53 AM
avendo's Avatar
Unless i need them both....
Old Jun 28, 2015 | 09:55 AM
plumbob's Avatar
This what you need:http://www.ebay.com/itm/One-Evap-Eva...11dd19&vxp=mtr
or (same part confirmed with a dealer site because eBay incorrectly says It's not compatible with your Intimidator).http://gmpartsdirect.com/catalog/frameset.cfm
Old Jun 28, 2015 | 10:41 AM
avendo's Avatar
Im at pepboys they have it for 24 bucks... Not acdelco
Old Jun 28, 2015 | 10:54 AM
plumbob's Avatar
Dorman?
Old Jun 28, 2015 | 11:03 AM
avendo's Avatar
some other name...will put it on later..
