Engine won't stay running...
Old Jun 23, 2011 | 03:25 AM
drmrgal's Avatar
Been there done that still having the same problems.I like my Monte but I don't want to drop a fortune on it replacing a bunch o parts and still have the same problems.whatever happened to points and carboraters.at least I could work on those.
Old Jun 23, 2011 | 06:22 AM
monte07's Avatar
the only thing i can think of is having a diagnostic done to get a narrow down problem. then hit and miss i have been there as well till i said the heck with it. it is getting expencive throwing parts on it. some times it could be some thing really obviuse that can be over looked like a bad ground to a bad conection to a knock sensor throwing some thing off till it gets replaced. what i am saying is get a diagnostic done then get the money to get that just that fixed
Old Jun 23, 2011 | 08:30 AM
Slickster's Avatar
Well, I'm going for a shot in the dark, here. I ordered a PCM off of Intense-racing.com. I've been wanting one for a while just for the performance increase, and I figured this would be as good a time as any to get one. Considering a lot of the things I am reading are pointing to the PCM, we'll see what happens. I should get it Saturday, and I'll post back here with my results. If this doesn't fix it, I think I'm going to have to bite the bullet and take it to a shop here to have it checked out. I just don't have the resources to locate the problem. Talk to you all soon.
Old Jun 23, 2011 | 08:37 AM
Because having to do the timing every time it rains was so much more fun :p
To the OP, good luck with the PCM, don't forget the check the wires too when you replace.
Old Jun 23, 2011 | 10:34 AM
drmrgal's Avatar
Cool slickster on the pcm let me know something soon so I might be able to follow you down the rabbit hole.I've been thinking that its primarily been coming from the pcm as well.
Btw I don't mind checking timing in the rain I just don't like the water spots it leaves on my old morosso valve covers.
Old Jun 23, 2011 | 02:30 PM
Slickster's Avatar
My PCM just shipped. I ordered it USPS Express mail, so it should be here Saturday. Hopefully you'll hear from me again this weekend and I'll let you know how everything went. Talk to you all soon.
Old Jun 25, 2011 | 12:02 PM
Slickster's Avatar
PCM won't be here til monday I hate ordering things during the second half of the week. Always such a let-down...
Old Jun 28, 2011 | 07:06 PM
Slickster's Avatar
PCM didn't fix it. I was sure it was gonna make a difference. No-go, though. Since installing it, I've taken out the MAF Sensor and the IAC Valve and cleaned them both, as well as the entire throttle body. I took the EGR Valve out to check it out. I cleaned it, and nothing looks out of order. I just don't know what do anymore. I am afraid I might have to bite the bullet and take it into a shop and get it checked out.
Old Jun 30, 2011 | 09:20 PM
Slickster's Avatar
I replaced the Crankshaft Position Sensor yesterday. Drove it around for an hour or so after I was done. Ran great. Stalled once. Went to start it this morning to go to work, same thing happened. Same problem exists. I broke down and took it to the dealer earlier. Hopefully they can help me out.
Old Jul 1, 2011 | 09:59 AM
Keep us updated, I'm very curious!
