Engine,transmission and ignition swap. No crank.
I did complete engine and transmission swap, along with ignition switch. When I turn key to on position everything comes on including the fuel pump. But will not crank over. Also tried resetting the security passlock. No luck. Any ideas?
Originally Posted by Dirtybyrd417SS
(Post 702552)
did you ever solve This ? I have the same problem |
