Engine light
Old Dec 10, 2013 | 05:03 PM
esespike818's Avatar
Exclamation Engine light
does anybody know how to check whats the problem when engine light on?
what kind of computer or device you used to check it?
Old Dec 10, 2013 | 05:20 PM
dbaldwin's Avatar
Go to autozone or any other auto store and ask them to check your codes for you. Its free. The use an obd2 scanner.
Old Dec 10, 2013 | 05:45 PM
A 1985 Monte is not going to work with an ODB-II scan tool (unless the tool is compatible with pre-ODB-II systems).
I believe on GM cars from the 80's, you can jumper two pins together on the computer terminal under the dash. After that, turn the key to the on position and the light will flash the code.
I believe the Haynes and Chiltons books will tell you how to retrieve the codes and what flash codes translate to.
Old Dec 10, 2013 | 05:48 PM
dbaldwin's Avatar
Hahaha sorry. I assumed 5th or 6th gen. I forgot the pre obd2 systems.
hotrodharley
Nov 15, 2013 11:37 AM
moemusic
Mar 16, 2011 04:26 PM
Mex24x
29
Feb 17, 2010 12:35 PM
gohawk72
Oct 2, 2009 02:14 PM
mikeymontecarlo
May 1, 2008 02:41 PM
