Engine light
does anybody know how to check whats the problem when engine light on?
what kind of computer or device you used to check it? |
Originally Posted by esespike818
(Post 585097)
A 1985 Monte is not going to work with an ODB-II scan tool (unless the tool is compatible with pre-ODB-II systems).
I believe on GM cars from the 80's, you can jumper two pins together on the computer terminal under the dash. After that, turn the key to the on position and the light will flash the code. I believe the Haynes and Chiltons books will tell you how to retrieve the codes and what flash codes translate to. |
(Post 585104)
