Electronic Brake Control Module
Old Jun 4, 2012 | 01:20 PM
bikerboyzzky's Avatar
Angry Electronic Brake Control Module
Needing assistance with how to remove the EBCM on a 2000 Chevy Monte Carlo LS, 112,000 miles 3.4L. Having problems out of intermittent ABS light with ABS code C1218 (Pump Motor Shortage or shortage in Pump Motor Circuit). Assumed the problem was the ground wire running from the EBCM/Brake Modulator Valve but doesn't seem to be the problem. Check the ground and re-routed the wire to another place on chasis, upper frame area. Still have ABS light on! Seems to come on as soon as transmission is put in drive. Just replaced right front wheel bearing after seeing a chipped on sensor wire. Apparently, that wasn't the problem! Someone say I should dismount the EBCM where it connects to the brake modulator valve to see if the inside of connector is corroded and or whether or not there is brake fluid inside of it. Need to know how to unmount this thing! Allddatdiy.com say to unlock red tape or something of the sort; I've no clue as to how to do this! Has any of you done this before? If so, how and thanks? Also, could the problem be a bad sensor wire not sensor?
Old Jun 4, 2012 | 01:44 PM
03SSLE's Avatar
Here's a diagnostic procedure that might be of help. It's for an '03 Impala, but should be the same for a Monte Carlo.
(Scroll about 1/2 way down the page)
2003 Chevrolet Impala Problem Chevy Abs Light Service Traction Control Brakes...
Old Jun 5, 2012 | 08:27 AM
Thanks[
quote=03SSLE;464334]Here's a diagnostic procedure that might be of help. It's for an '03 Impala, but should be the same for a Monte Carlo.
2003 Chevrolet Impala Problem Chevy Abs Light Service Traction Control Brakes...[/quote]
wnmech
Sep 3, 2011 05:56 PM
walkingonabullet
Jul 23, 2011 12:39 PM
glenn
May 12, 2009 02:32 PM
kweef
Mar 9, 2008 07:39 PM
orthokneepa
Dec 2, 2006 12:19 PM
