6th Gen ('00-'05): EGR Valve
Old Aug 13, 2018 | 03:43 PM
Das Aamon's Avatar
Question EGR Valve
My 2005 3.8 Monte has been having troubles with everything lately, the main thing is it not staying on and dying after a while of driving. Battery was replaced, starter was replaced, and alternator tests fine. We've checked every other possibility and the last two ideas that are available is the body control module and a EGR valve problem. I'm gonna be taking the body control module out this afternoon, but a friend suggested the EGR valve killing the car after going 30 mph for an extended period of time. My only problem is that I have no idea where the EGR valve is at in the engine. Where would it be located? Is there any definite characteristics of it that shows it's for sure the problem once I find it? Much appreciated if any of ya'll can help.
Old Aug 14, 2018 | 08:49 PM
EGR valve is located on the drivers side of the rear valve cover. You'll see it connected by two metal pipes/tube - one going to the rear exhaust manifold and the other going under the throttle body.
I cant be of much help with diagnosis though, without some scan data of the sensors, it's hard to guess at what might be wrong.
Old Aug 15, 2018 | 11:18 AM
coolhand's Avatar
The body control module should not have anything to do with the car dying. Is your check engine light on? Did you check if the fuel pressure regulator is leaking? The MAF sensor could be bad but that normally would throw a code.
antoniodeMONTECARLOmiller
Apr 22, 2018 10:31 AM
David D
Feb 22, 2018 05:19 AM
lucasmblanco
May 28, 2014 11:31 PM
ohara
23
Sep 13, 2013 09:50 PM
Camberleigh
Feb 1, 2013 11:38 AM
