EGR Code STILL! GRRRR!
Old Oct 11, 2016 | 07:26 PM
Tma's Avatar
Tma
Default EGR Code STILL! GRRRR!
Ok hoping someone's had this issue and has an answer for me.
Throwing an EGR code, we've replaced the EGR valve and gasket, MAF, 02 sensor, pulled the EGR tubes and cleaned them out, only have 40,000 miles on the CAT.
Cleared the codes twice and after about 10 miles down the road the Friggin CEL lights up with an EGR code. What am I missing???
Old Oct 12, 2016 | 12:26 AM
Can you share what codes you are currently getting?
And what year and engine do you have?
Old Oct 12, 2016 | 06:04 AM
Tma's Avatar
Tma
I'll have to get the "P" code this morning. I've got an 01 3.8.
I'll post the code # as soon as I get it.
I do know it's defiantly EGR code tho.
The MAF was bad but never threw a code, we changed it because of the issue we were having and it straightened out that problem. But this EGR code is really driving me crazy.
Old Oct 12, 2016 | 06:28 AM
Could be a vent solenoid code for the gas tank. Common for those to get clogged up.
We can help further when you let us know the exact code that you are getting
Old Oct 12, 2016 | 01:06 PM
Tma's Avatar
Tma
The exact code is P0401 Insufficient EGR Flow Detected. It's been throwing this code since my car started acting up.
Old Oct 12, 2016 | 04:07 PM
Check the connectors, sometimes those prongs can get messed up. Might not be a hard part, but the sensor that reports to the PCM giving a false reading.
I have also heard that a map sensor issue could throw a common EGR problem code.
Old Oct 12, 2016 | 06:55 PM
Tma's Avatar
Tma
MAP sensor is new also sois the PCV valve. I'll check the connectors in the morning. What amen looking for exactly? This way I'll know if I'm seeing a problem or not.
And Thank you for your help this car had been a stresser to get straight this past 3 1/2 weeks.
Old Oct 12, 2016 | 08:17 PM
Tma's Avatar
Tma
Also I ment to ask what is the name of the sensor that your talking about, so if I need to replace that also I'll know what to purchase.
Old Oct 13, 2016 | 10:50 AM
It's the connector to the actual EGR itself. Here's a good page about diagnostics and doing multimeter testing for the system: Part 1 -How To Test the GM EGR Valve -Buick, Chevy, Olds, Pontiac
Old Oct 13, 2016 | 10:44 PM
nitehawkjcb's Avatar
Make sure the EGR tubes aren't cracked
