DuAL Control Issue
Please help before winter! The passenger AC and heat control is lit up and working fine, but my Driverside Heat does not light up and doesnt switch to heat when I control temperature.
The bulb is probably burned out behind the drivers side, not a big deal both mine are out I'll have to replace them one day, as for it not switching its probably the blend door motor. You can hit the blend door motor with a screwdriver and it may work, but you'll end up replacing it eventually.
