Drivers window weatherstripping replacement
Old May 21, 2010 | 07:59 AM
ohbob's Avatar
Default Drivers window weatherstripping replacement
I can't seem to find how to replace the weatherstripping around my drivers side window. It is the big one that goes around the top of the window and I believe down the inside front of the door. The window sticks in the front inside section and the window will not go all the way up. It appears that the front inside section is bent somehow. The part is very expensive so I want to do this right. Yes, I've had the door panel off, but it is hard to tell where the bolts are that holds it in. Thanks...Bob in Ohio
3vom
Apr 20, 2014 05:14 PM
Flash
Sep 26, 2013 11:02 AM
michelob
Jul 16, 2013 08:54 PM
montecarloLS350
Aug 5, 2011 11:56 AM
lowridincrew
Jan 14, 2008 11:49 PM
