dashboard assembly to get a cd player in??????
Old Mar 11, 2007 | 10:29 PM
shibby600cc's Avatar
Default dashboard assembly to get a cd player in??????
so can someone tell me how i take my dash board apart before i screw something up i need to put a cd player in thanks
corey
Old Mar 12, 2007 | 01:34 AM
mickey's Avatar
Default RE: dashboard assembly to get a cd player in??????
C-4 works great in moderation LMAO!!
ok sorry had to
but take off the fuse pannel on the drivers side and remove the screw there, there is also one in the glove box
and you have to take the bottom part of the dash apart above your legs when your in the seat.
then you have to set the park brake
turn the key to the start position and put the car in to first gear.
turn car back off (dont move gear shifter)
then carefully pull on the dash working your way around the dash to get it free. it might be stubron but it will come off there.
Also becareful that you dont tear the key out of the Ing. taking out the dash. If you do it is a good chance your car wont start with out replacing it .
Good luck
emilyon
Jul 3, 2011 06:56 PM
Herlsy
Apr 1, 2011 11:11 AM
kpreisler
Mar 29, 2007 03:18 PM
swanny31
Jul 7, 2006 08:33 PM
rob559
May 22, 2005 11:34 PM
