Dash lights and running tail lights don't work in the dark
Old Oct 25, 2011 | 11:29 AM
01LS Goin Bad's Avatar
Default Dash lights and running tail lights don't work in the dark
Having searched and read some of the posts on this issue, I've come to no conclusion on how to fix it. Admittedly, tearing the dash panel off was kinda fun, probably mostly because I am no mechanic. But I am still frustrated.
-Headlight switch is turned to the correct setting.
-Fuses all appear good.
-Tail bulbs are good.
-No fouling/shorting apparent on the headlight switch contacts.
What's my next step?
Old Oct 25, 2011 | 11:45 AM
nitehawkjcb's Avatar
Could be the Body Control Module going bad
Old Oct 25, 2011 | 02:39 PM
Will a bad BCM definitively throw a code on a scan?
Maybe I can do the auto parts store scan.
Old Oct 25, 2011 | 06:38 PM
There is a possibility that it WON'T throw a code, as with all electronics
Old Oct 28, 2011 | 12:48 AM
MJClemm's Avatar
Hello, dude I had the EXACT SAME PROBLEM last week, my rear running lights (at night) and my dash lights (at night) would not work at all, I went thru EVERYTHING YOU DID, I have the huge shop manuals from GM, went thru the entire system and everything pointed to 1 item, every single scenario I did, still 1 point of interest... On the passenger side fuse panel , the 2 Nd fuse from the bottom, , the 15 amp fuse, it read GOOD with a fuse tester, then I went thru them all again with a continuity tester, guess what, BAD FUSE, I pulled it, replaced it and to my astonishment, EVERYTHING TURNED ON ! I swear to you, I checked that fuse 3-4 times with a fuse tester." I was so frapin happy, then ticked off because I have a fuse tester that indicates all fuses are good, even though it was bad. I tested the fuse (the bad one) again with the fusee fester after I REMOVED IT, It still showed GOOD and you could see that it was in fact bad, huge issues avoided there after that... Very relieved Just check...Mjc....
Sidestreet
May 22, 2015 10:48 AM
monteriderLS
Apr 1, 2013 08:57 AM
TKG2000
Nov 28, 2011 02:03 PM
DouglasGabriel
Jun 7, 2010 05:43 PM
espo83
Sep 12, 2008 10:00 PM
