cv joint? transfer case?
Old Apr 30, 2011 | 06:45 PM
crete's Avatar
Default cv joint? transfer case?
I'm trying to figure out whats up with my wife's car.
2000 Monte SS
While driving at 40+ mph there is a very noticeable vibration. You can feel it in the steering wheel and in the front end of the car.
It seems to only do it after the car has been driven for a while.
The tire on that side was also wearing unevenly.
I don't hear any pops when I hit corners, but when I accelerate the vibration gets bigger.
Is there a way to check the cv joint for damage or to check the transfer case for issues?
Old Apr 30, 2011 | 08:36 PM
nitehawkjcb's Avatar
Could be a bent rim, out of alignment, ball joints going bad
Old Apr 30, 2011 | 08:42 PM
jwjones's Avatar
I completely agree with nitehawk. By the way a Transfer Case is not something you will find on a 2WD car. Transfer Cases are on 4WD cars only.
Old Apr 30, 2011 | 09:01 PM
crete's Avatar
Ok, thanks. I'm used to RWD cars. I thought it was a FWD thing.
I changed the tire on that rim and they never said anything about the rim being bent. It did it before and after I got the tire changed.
I tried taking it for an alignment today and they said that it wasn't a symptom for needing an alignment. They even took it for a test drive.
But then again they told me it may be the transfer case. Maybe they should have sold me some blinker fluid while they were at it.
Old May 1, 2011 | 12:02 AM
lol blinker fluid ftw
One of my Prelude's ball joints is going bad and has the same symptoms as what you're describing other than the uneven tire wear
Old May 1, 2011 | 12:06 AM
jwjones's Avatar
LOL @ blinker fluid.. ahh thats good stuff... played that trick on a girl last week with her brand new f150....
anyways back on topic. I would definitely look at getting your ball joints looked at.
Silver SLP
Oct 23, 2012 06:08 PM
adryan16
Sep 19, 2012 11:27 AM
vincenti
Jul 25, 2009 07:08 PM
zipsayain
Jul 31, 2006 03:39 AM
