Cv joint interchange hello!
Are you referring to taking apart the axel or just swapping the cv shaft ? Do either of the cars have an ABS sensor ? The price of a new/rebuilt CV shaft is pretty cheap, so taking one apart and swapping joints, buying boot kits ( boot, grease, clamps) would probably cost more than a shaft with warranty. If you're wondering if they are the same ( interchangeable) you can match them up side to side and decide. Option "B" would be call the part's store(look online) and check to see if the part numbers are the same.
6th Gen ('00-'05): Transaxle shaft on lh side loose
gtr25
03-16-2016 10:26 PM
indawuz
03-18-2010 08:49 PM
