Cv joint interchange hello!
Old Mar 12, 2022 | 01:40 AM
Lovelyanarchy's Avatar
Default Cv joint interchange hello!
Can I use cv joints from 04 Impala on my 98 Monte?
Old Mar 12, 2022 | 10:08 AM
Jeffs02rwdSS's Avatar
Are you referring to taking apart the axel or just swapping the cv shaft ? Do either of the cars have an ABS sensor ? The price of a new/rebuilt CV shaft is pretty cheap, so taking one apart and swapping joints, buying boot kits ( boot, grease, clamps) would probably cost more than a shaft with warranty. If you're wondering if they are the same ( interchangeable) you can match them up side to side and decide. Option "B" would be call the part's store(look online) and check to see if the part numbers are the same.
v6racer
Apr 15, 2019 12:15 AM
gtr25
Mar 16, 2016 10:26 PM
GTHSS
May 26, 2015 12:01 AM
zillatattoo
Oct 28, 2011 09:29 PM
indawuz
Mar 18, 2010 08:49 PM
