couple quick questions
Old Mar 10, 2010 | 10:52 AM
aussiek2000's Avatar
Default couple quick questions
So i am looking to get a dash daq monitor for my car (2004 LS). The only questions I have.
1. Can I see the trans temp with the obd II port?
2. Can I view oil presssure
In case you don't understand. I just want to know if on a scanner you can view these parameters.
Old Mar 10, 2010 | 11:29 AM
RickAKATed10's Avatar
Photobucket
Old Mar 10, 2010 | 03:56 PM
Sorry. I was unclear. I know the dash daq can read these on some cars. But do our monte even have this information available or is there only a dummy light when the pressure gets low? If I were to hook up a tech 2 scanner to my car, could I see oil pressure and trans temp on it?
Old Mar 11, 2010 | 09:31 AM
JaxJim's Avatar
I recently bought a ScanGaugeII (the cheap version of what you're buying) and I'm using it on a 99 Monte. It will read Trans Temp, but not oil pressure or oil temp. I believe that you are sometimes limited not only by the limitations of the car (PCM) but also by the maker of the monitor (ScanGauge or DashDAQ). Someone needs to figure out the computer langauge to pull the info out of the PCM. My ScanGuage appears to be much more limited in what it can read.
tps221
Sep 21, 2012 09:43 AM
custom95
Apr 13, 2009 01:30 PM
Brinksta
Aug 3, 2008 02:34 PM
98monte
Feb 28, 2008 01:18 PM
Epic
Oct 7, 2007 11:57 AM
