Cooling Fan issues?
Dear readers,
I happened to notice the other day that well my fans dont work when the car gets hott? or when i turn on the ac or the heat to any standerd now both of them do not work is it a fuse or a relay???
thank you
thank you
Hey ZK, check out this link to another post about this topic and hopefully this helps. Also, if you want help with a tehnical issue, please provide your year/motor size to us, that would help greatly. Thanks!! Here is your link:
https://montecarloforum.com/m_83314/tm.htm
I have a haynes manual and traced the wiring schematic. Usually if a system has relays in it I go for those first as they take a hit after years of use. I went for thr Fan1 relay because it controls both fans. Hope this helps you out.
Hey blazerman turns out i tested both fans and the primary fan motor on the driver side did not work and it turns out they turn on now ...question are they suppose to turn on with the ac though??
