Cooling Fan issues?
Old Mar 24, 2008 | 09:02 PM
zk6216's Avatar
Default Cooling Fan issues?
Dear readers,
I happened to notice the other day that well my fans dont work when the car gets hott? or when i turn on the ac or the heat to any standerd now both of them do not work is it a fuse or a relay???
thank you
Old Mar 24, 2008 | 11:15 PM
rysZ34's Avatar
Default RE: Cooling Fan issues?
Hey ZK, check out this link to another post about this topic and hopefully this helps. Also, if you want help with a tehnical issue, please provide your year/motor size to us, that would help greatly. Thanks!! Here is your link:
https://montecarloforum.com/m_83314/tm.htm
Old Mar 25, 2008 | 03:43 AM
blazerman3's Avatar
Hey.....had the same problem the other day....with my `98LS....it was the Fan 1 relay....hope this helps.
Old Mar 25, 2008 | 04:18 AM
rysZ34's Avatar
Actually, Blazerman....You are who I was thinking of when I posted that link! So thanks for posting your previous thread and this one!
Old Mar 25, 2008 | 08:59 PM
zk6216's Avatar
hey thanks guys its a 97 ls and the motor is 3.1 and i hoping to god its the relay lol did you check it and it did not click or how did you tell?
Old Mar 27, 2008 | 03:12 PM
blazerman3's Avatar
I have a haynes manual and traced the wiring schematic. Usually if a system has relays in it I go for those first as they take a hit after years of use. I went for thr Fan1 relay because it controls both fans. Hope this helps you out.
Old Mar 27, 2008 | 08:04 PM
zk6216's Avatar
Well it turns out i checked out all the relays and they are all good... turns out i poped the plugs and the secondary fan works but the primary is a no go so im guessing the motor?
Old Mar 28, 2008 | 01:57 PM
blazerman3's Avatar
If you have power to the fan`s plug then it`s the fan motor itself.
Old Apr 2, 2008 | 04:54 PM
zk6216's Avatar
Hey blazerman turns out i tested both fans and the primary fan motor on the driver side did not work and it turns out they turn on now ...question are they suppose to turn on with the ac though??
Old Apr 2, 2008 | 05:07 PM
blazerman3's Avatar
I think it depends on the air temp with the A/C. If you go to MAX the secondary will cut in but the primary will not till the engine temp gets on up there a ways.
