Coolant leak fixed...
Old Sep 13, 2006 | 08:58 PM
orthokneepa's Avatar
Default Coolant leak fixed...
I finally fixed the coolant leak. It did end up being the water pump. The only thing now is that I still get a low coolant light intermittantly? Im not sure why that is the coolant defenitly isnt low.
Where is the coolant level sensor on a 2000 LS?
Old Sep 13, 2006 | 09:44 PM
InTheIROC's Avatar
Default RE: Coolant leak fixed...
I do believe it is in the passenger side tank of the radiator, near the top.
Old Sep 14, 2006 | 12:47 AM
DESS03's Avatar
did u bleed the air out of the coolant system
Old Sep 14, 2006 | 04:34 PM
01pacecar's Avatar
InTheIROC is correct about location. I've had to replace mine twice on my '01. You have to take the battery out for clearance and then it's still tight in there.
Old Sep 14, 2006 | 07:59 PM
Ive bled the coolant system 3 times, there defenitly isnt any air. I will try replacing the sensor. Thanks!
MonteSquarlo
Dec 16, 2012 06:18 PM
jay26
Mar 16, 2008 06:37 AM
2000LS
Jan 28, 2008 08:00 PM
autonoz
Dec 28, 2006 12:27 AM
greg fell
Jul 19, 2006 10:59 PM
