Coolant?
the car requires dexcool I use the Prestone 50/50
here is a link
http://www.google.com/#q=dexcool&hl=...9296d7465e28c1
just don't use the green it will plug up you radiator
here is a link
Should be Dexcool but look at it, if it's orange it's Dexcool, it's it green it's been changed to regular antifreeze. Do NOT mix them!!! If you want to switch from orange to green you'll need to flush the system several times to get as much as possible out. I've also heard not to use the yellow (mixes with all colors) with the Dexcool even though it claims it's safe.
