Compass
Old Jun 10, 2015 | 06:52 AM
avendo's Avatar
Default Compass
well I read a few other threads about it,but im in same region and my compass keeps screwing up...is there a sensor you can change?
Old Jun 10, 2015 | 05:01 PM
You may have to set the compass for a specific zone and re-calibrate. BBEngineer posted the steps from the shop book in the troubleshooting section at the bottom of this page:
Impala DIC Retrofit
Old Jun 10, 2015 | 05:15 PM
avendo's Avatar
I have done that but it goes out on its own,how many times do you have to calibrate it?
Old Jun 10, 2015 | 06:31 PM
Did you verify your zone before you calibrated? That will play some role in to it.
My Monte did not come with a DIC, so when I added it, I verified the region/zone, then had to calibrate it and it was a 1 and done process (prior to that, it would not read correctly at all). And it did not take long to calibrate, drive in a circle under 5 mph and by the time I finished circle #1, it was done.
Old Jun 10, 2015 | 07:53 PM
avendo's Avatar
yea mass,its still the same unless the world changed
Old Jun 10, 2015 | 10:44 PM
Gotcha. Wasn't sure if perhaps the DIC reset the region on you. If not, maybe the electronics are just going bad.
Old Jun 11, 2015 | 02:01 PM
avendo's Avatar
yea its working today,go figure..
Old Jul 22, 2015 | 04:56 PM
avendo's Avatar
what do you replace if its bad?
Old Jul 23, 2015 | 09:59 PM
On cars with a sunroof, I believe the compass module is a small board by itself for the DIC. For cars with no sunroof, all contained in the DIC.
Best bet, just replace the DIC if you want to see if that is the source of the issue.
Old Jul 24, 2015 | 06:02 PM
avendo's Avatar
and they cost? maybe junk yard?
