Codes
Old Oct 13, 2012 | 06:16 PM
rj's Avatar
rj
Default Codes
2003 Monte Pace car.
Last night while driving home from a cruise-in all the lights shut off. The dash light flashed "SECURITY" and "BATTERY."
The stereo flashed "LOCKED."
The car continued to run. But we were only a few miles from home. Once home the car would not re-start.
I thought it to be a shorted battery. So after fighting to get the battery out of my '86 Monte in the Pace car, the car now acts like it's shorted some place. Like the battery clamps.
Is there some place on the net I could research what this means to diagnose the car's problem?
Old Oct 15, 2012 | 12:04 AM
rj's Avatar
rj
No one has any ideas what may be causing this?
Or do I need to ask on anouther board?
Old Oct 15, 2012 | 12:09 AM
Budsjlm's Avatar
RJ i got nothing for you exept maybe replace the bat cables, clean the key, my 01 was having similar issues that i do belive was bat cable issue, still have yet to find out, hasn't had the issue for months also didn't get locked out and no light
Old Oct 15, 2012 | 12:37 AM
See, the locked on the radio is theft lock activating. DOn't quote me as I lack enough knowledge on this, but it could be a failing or failed BCM. If you can get it to a dealer and have a guy strap a GM Tech II to it, that may open more information.
Old Oct 15, 2012 | 07:13 AM
Hi R.J., sorry I have no idea on how to help you on this problem , but it's great to see you online
I hope that you find a solution to this problem & I hope I see you more often on the MCF
Peace/Happiness from `Space
Old Oct 15, 2012 | 07:27 AM
03SSLE's Avatar
I would do a security relearn (key ON for 11 min/OFF for 30 sec/X3) and see if that resolves the problem.
This is part of the security system. It should unlock once the security relearn is done. If it doesn't then you may have a faulty ignition switch or possibly bad BCM wiring or BCM.
Old Oct 17, 2012 | 09:22 PM
rj's Avatar
rj
Man I hope it's not something like the BCM. I'll bet they aren't cheap.
I checked in to new battery cables today. GMpartsdirect wants $45/each. Since I want to stay with stock looking parts I guess this isn't too bad.
Old Oct 17, 2012 | 09:50 PM
boggie's Avatar
I had a similiar prob first it would not start if it sat awhile cooled down it would start. Then it got worse tried the leave ligth turn ingnition three time get out turn around three times and it would start. So went to the dealer and had a new ignition put in and solved the problem worth a try Good Luck
jiffdaddy
Dec 9, 2007 07:04 AM
erik2282
Oct 7, 2007 01:00 AM
BLACK ATTACK
Sep 5, 2007 07:49 PM
djplayap
Aug 1, 2007 09:54 PM
scc24540
May 21, 2007 07:48 PM
