Code p0128 problems.
Old Feb 9, 2014 | 01:09 PM
cimber's Avatar
Default Code p0128 problems.
So I replaced the thermostat and the ect sensor. It's still running the fans all the time. It puts out heat. Just not really hot heat. So what else could it be? I have a 2000 Monte Carlo SS. 3.8l. I'm lost. Only thing I can think of is a wire has gone bad. Any help please.
Old Feb 9, 2014 | 02:10 PM
03SSLE's Avatar
Check the cooling fan circuit. You may have a bad relay or (as you suggest) a bad wire in the harness. Once you get the fan situation under control I have a feeling your P0128 problem will go away. Even though it indicates a problem with either the thermostat or ect, you have to keep in mind the code will also be triggered if coolant temp is too low. With the fans constantly running from start up the coolant may not be reaching operating temp within the allotted time before the PCM sets the code.
Boxer7570
Sep 7, 2013 11:18 PM
montespython
Jan 25, 2011 01:38 PM
widebody
Oct 19, 2010 06:23 AM
JAFO
Mar 10, 2010 09:10 AM
turner_dtp
Sep 5, 2008 04:32 AM
