Cigarette Socket Solar Charging
Old Feb 2, 2012 | 09:24 PM
vindicator's Avatar
Default Cigarette Socket Solar Charging
1995 Monte Carlo Z34
I replaced the blown fuse in the cigarette adapter and check the voltage(V) with my multimeter(MM).
Straight from the adapter, I got 14 V. When plugged into the socket, I got maybe 1V at the terminal ends.
I checked the continuity of the fuse for the cigarette socket and that's fine.
I put my MM leads in that same fuse socket with my adapter plugged into the socket. and got the same 14V.
Somewhere I lose the connection to the leads to the battery.
I've read of references of relays being used so no power goes to/from the cigarette socket while the ignition is off.
I don't know if this is the case with this model and was wondering what the path is for me to check between the cigarette socket to the battery.
bblackstone
Dec 7, 2014 01:31 PM
atg284
15
Jul 16, 2012 02:02 PM
03SSLE
May 18, 2012 08:03 AM
RickAKATed10
Apr 13, 2011 04:22 PM
Jul 20, 2009 09:08 PM
