Checking Codes While Charging Battery
Old Oct 18, 2018 | 02:01 PM
WolvenScout's Avatar
Default Checking Codes While Charging Battery
I purchased an automatic battery charger and an OBDII scanner this morning. I'm currently charging the battery, which was low. But I wanted to know if it is okay to have the electronics on (not the engine) while the battery is charging, so that I can check the codes with the scanner. The manual for the charger didn't say I had to disconnect the battery terminals, nor did it say anything about using the electronics.
Pyles41
May 27, 2019 09:48 PM
96z34man
Jan 13, 2017 01:41 AM
avendo
Feb 19, 2015 05:30 AM
owens91
Jan 24, 2014 10:30 PM
rj
Mar 15, 2007 08:40 AM
