Car won't steer to the right
Old Oct 19, 2018 | 01:51 AM
Skul's Avatar
Default Car won't steer to the right
01 Monte Carlo SS 3.8L. The car steers left just fine. It will steer to the right but only if you turn the wheel very gently. The moment you put normal pressure to the right the steering wheel itself pops but the car goes straight. Any ideas?
Old Oct 19, 2018 | 05:20 AM
Jeffs02rwdSS's Avatar
That's a very unusual problem and sounds pretty scary to drive. My best guess is a gear in the rack and pinion is damaged which would entail swapping it out. There's also a u joint at the bottom of the collum that I would check. Good luck
musclecarfreak1235
Aug 4, 2024 10:41 PM
shicks255
Jun 29, 2014 08:03 AM
lraklrak
Nov 24, 2013 05:20 PM
Griffindor
Aug 26, 2013 09:56 AM
silver86
Nov 20, 2009 11:06 AM
