check engine light
Old Mar 25, 2011 | 09:59 PM
AJMDowling's Avatar
Default check engine light
ok so i plan on taking my car to pepboys and having it checked out soon but never have free time so i figured ill try here in the mean time. i have an 01 ls monte and recently i noticed that whenever i accelerate a little quick the check engine light flashes for a few seconds then will turn off. also i will randomly feel something i can only describe as my car wanting to stall . it feels as if somethings tapping on the brakes. not on the pedal itself but just the performance. any idea what this might be? i figured this is the best place for monte information!
Old Mar 25, 2011 | 10:03 PM
KJRich's Avatar
Flashing check engine light means a misfire is detected.
Old Mar 25, 2011 | 10:17 PM
Sounds like you have a random misfire...What code do you have ?
Old Mar 26, 2011 | 01:32 AM
AJMDowling's Avatar
thanks guys for the help. and i what do you mean when you ask what code i have?
Old Mar 26, 2011 | 07:40 AM
When you get the code read at an autoparts store they will give you the OBD-II code.
But yes you are misfiring, you might as well start changing the spark plugs and don't drive it.
Old Mar 27, 2011 | 12:33 AM
AJMDowling's Avatar
ok thanks for the advice and info. ill get on it right away
hotrodharley
Nov 15, 2013 11:37 AM
J_Bru_Ha_SS
Jul 30, 2007 09:08 PM
BeachBumMike
Sep 21, 2006 10:48 PM
malletboy
May 28, 2006 06:07 PM
rich131
Dec 16, 2005 02:07 AM
