Check Engine light on
Happy to be a new member, Looks like a great forum for Monte Carlo fans. I have a 2003 Monte Carlo SS with the 3800 V6. Bought new. The car has 133000 miles at this time. At 105000 miles it needed a catalytic converter. Replaced with a good quality converter $260 wholesale but didn't buy the GM replacement. Check Engine light is on and reading the code 0740 or 0470 I'd have to find the paper work. Cleared the light twice and then replaced the sensor behind the converter and the light came back on the next day.
Any help would be great.
Thanks
DJ58
Thanks
DJ58
it could be both the front or back sensor o2. good rule of thumb is to replace them both at the same time due to how the old one went could have taken them both out. but it could be a limp mode due to when the old one went it might need to have the battery disconected for a while when you clear the codes for a little to see if the sensor codes will clear finnally
Also if the code is P0420 then it's probably due to the fact that you are using an aftermarket Catalytic converter.
Nothing would be wrong with the cat or the sensor, but since it probably flows better than the crappy stock cat, it will throw that code. Many people who mod their cars have a problem with this when they do aftermarket downpipes.
Only options are to fake the sensor or to get the code programmed out of the PCM
Thank you for the info, I think we may replace the sensor's in front of the converter and behind and see if that takes care of the problem. My mechanic cannot cancel the codes from the PCM and doesn't know how to fake the sensors. Any info on faking the sensors might be helpful even in other problems they may run across.
Thanks
DJ58
Thanks
DJ58
The part I don't understand is this didn't start happening untill about 14 months after the new converter.
DJ58
hotrodharley
Nov 15, 2013 11:37 AM
