changed brake pads and now brake light and trac off light are on.
Old Jan 24, 2015 | 08:27 PM
matthew41's Avatar
Default changed brake pads and now brake light and trac off light are on.
So I just spent hours replacing my front brake pads on my 2000 Monte Carlo SS and drove around, slowly stopping like I'm supposed to but when doing this, because I'm driving in tucson where nobody knows how to drive, I had to hit the brakes kind of hard, after which I noticed my brake light and trac off lights on the dash were on. I parked and looked them over but they seem to be fine, they even brake normally from what I can tell. I don't really know what to think about this, it seems ok to me. I didn't have enough time to change the rear brakes, though. Could the light be on because the rear pads are too low? What should I look for when it's light out tomorrow?
Old Jan 25, 2015 | 07:22 AM
GTHSS's Avatar
My first thought is that the wheel speed sensor is loose or not sensing. That would make the traction light come on.
Old Jan 25, 2015 | 11:02 AM
Since you had to recompress the caliper...
Before you drove off to test them...
Did you pump the pedal a few times to be sure the brake pedal was off the floor.
Is there any brake fluid leaks anywhere?
Was the light on before you replaced the brakes?
My suggestion...
Check the codes to find out exactly what the problem is...
You should be able to go to any auto parts and have them scan it for codes.
Old Jan 25, 2015 | 11:22 AM
matthew41's Avatar
I checked and there were no leaks and I made sure to pressurize the brakes before getting on the road.
Jerry Barao
Jan 12, 2013 07:54 AM
ladagosta
Aug 24, 2012 09:54 AM
Franks 03SS
Jun 1, 2012 08:10 AM
silver86
Dec 25, 2011 11:59 AM
Gr4v3_7
Oct 12, 2007 08:07 PM
