Center Counsel
Old Mar 18, 2008 | 04:55 PM
God_Bot's Avatar
Default Center Counsel
I'm thinking about mounting the rocker switch for my subs on the side of my center counsel.
Any suggestions as to how to run the wires inside? I might just have to take the counsel apart to mount it.
Anyone know how to take the center counsel out/apart on an '06-'07?
Old Mar 18, 2008 | 05:21 PM
mickey's Avatar
Default RE: Center Counsel
how about a hatchet LOL
Nah , If it is close to the 03 version in the front under the dash is a rubber mat and you pull it up and the top then snaps off .
then inside of the cubby hole in the center there is a few screws way at the bottom of it that hold it to the floor. and in the midel by the shifter there are some also.
to get the top off you need to pull the shift boot down and then remove the clip that hoolds the handel on . just take a small screw driver and push on boths sides enough to get a screw driver in to the top of the clip and pop it out.
Also you will have to put the car in 1st. gear so tha tit will come back far enough to not hang up on the bottom og the dash
reverse to throw it back in
Old Mar 18, 2008 | 06:55 PM
RocknSS04's Avatar
Rockers? for what?????
Old Mar 18, 2008 | 07:21 PM
chuckd 06 ss's Avatar
1 place the shifter in neutral
2 remove console trim plate- cliped in
3 remove cupholder assembly- cliped in
4 remove 4 screws 2 under consle lid bottom of the consle and2 under trim plate
5 disconnect the electrical connecters
6 remove console assembly
Old Mar 20, 2008 | 01:11 PM
skidoo6713's Avatar
I have a few switches mounted right on the side of it. just past where the seat and counsel meet so you cant see them. it is a great spot for switches! just open the hatch, pop off the cup holder and screw right into the side with the seat as far back as you can. that is the best place to hide a switch!
Bowtie_Brother
Aug 9, 2006 06:29 PM
Moffer
Jul 17, 2005 12:28 AM
big green dog
May 5, 2005 05:17 PM
