4th Gen ('81-'88): carb acc pump sol & carb acc pump sol temp sw
What year is your Monte? It sounds like whoever had it before you removed all of the CCC and smog parts. They added a standard Quadra jet and distributor probably. I have a 1987 El Camino with the CCC carb. The acc sol is the accelerator pump solenoid, so those wires are not needed for a non ccc carb.
So the 1987 305 all came with the CCC carb and distributor. The V6 had the TBI fuel injection. The good news for you is they added a non CCC carb and distributor, which make things easier for adding your early model 327. Not sure where the oil pressure sender would fit on a 327, there was an oil pressure sender on the back of the block behind the distributor but I think that was for the idiot light on the dash.
Dave
Dave
Dave
Dave
Yeah the tach filter could be bad. Only reason they have that is to stop radio noise, but they often fail after 30 years and as far as I know you can't get an aftermarket or nos one anyplace. I just run a wire from the coil to the white tach wire inside the dash.
