4th Gen ('81-'88): carb acc pump sol & carb acc pump sol temp sw
what are the "carb acc pump sol" & "carb acc pump sol temp sw", i am chasing a pink wire with a black trace (#39), from the engine bay, according the wiring diagram they go to the gauges. im also not sure what NM5 is, or if my car has it?
it is not a CCC, and i don't believe it ever was, model number is 17056228 (17056228 Carburetor Info Page)
didi these cars have modular wiring or was it only specific to what options it had, would i have extra un used plugs in the engine bay?
like the first picture it shows Oil press & oil press sw, i know the line is dashed for the sw, but i have a un used connector in the same area as the Oil press conector ?
As for the wiring the factory would use the same harness for the same engine regardless of the options (cruise,air or gauge options) they would obviously have a different harness for a chevy 229, buick 231 , chev 5.0 hope I helped a little.
What year is your Monte? It sounds like whoever had it before you removed all of the CCC and smog parts. They added a standard Quadra jet and distributor probably. I have a 1987 El Camino with the CCC carb. The acc sol is the accelerator pump solenoid, so those wires are not needed for a non ccc carb.
